HP Pavilion dv6000z Notebook Logo
Posted on Aug 04, 2008
Dvd region change
Hi, I'd like to be able to play region 1 dvd's on my locked in region 4 laptop player. It is a HP Pavillion dv6547TX.
Thank you so much
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Aug 07, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2042
Points
9
Try using DVD43 or AnyDVD software which both bypass the region encoding/lock!
2answers
Hp laptop wont play any dvd
see this i windows, it tell what drive is there
then from this fact we move top a cure.
to view the movie, this is best and free google it./
then load free VLC and it plays.
4answers
Problem with the Dell Inspiron 1720 Laptop Computer DVD Drive Locked to Regon 1 & i live in Regon 4
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware that allows you to play DVDs from any region. There are severalavailable on the Internet but my favourite is DVD-Region Free From: -
www.dvdidle.com/dvd-region-free.htm
2answers
I need to change the region code from the US to the UK for my HP Pavillion dv2000 laptop. The hardware under properties says its a slimtype DVD ADS8A1H ATA device? I have already gone past the 5 allowed...
If you have used the 5 allowed changes, then your device is locked at the last one. You may be able to unlock it so it works region free. There are tools on the internet that allow you to do this.
The free way is to just install videoLAN (VLC). If yo use videolan as your video player, it should play any dvd without needing to modify firmware or "hack".
If you want to try to modify your locked DVD region codes, a good place is www.videohelp.com. Here is the direct link to the regon page:
http://www.videohelp.com/tools/sections/region-free-tools
Regards,
Chris
3helpful
2answers
DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
1helpful
My dvd region is locked and I need to change it. How?
2answers
DVD Player region coding changes
You can only change the region code 4 times then it locks on the last change.
There are some firmware upgrades that can change the drive to region free, if you can screw it up or put in the wrong frmware upgrade then the DVD drive will be a piece on junk.
I suggest you install a region free software that will allow you to play and region DVDs.
Go to www.dvdidle.com to get their Region-Free software, it is not very expensive.
2answers
Need to make laptop notebook packard bell dvd region free locked on o1
You can only change the region code up to 4 times then it locks on the last change.
I suggest you install a region free software that will allow you to play any region DVDs.
4answers
Changing DVD region code on player
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
