Question about Microsoft Multimedia Keyboard/Wireless intelliMouse Explorer K5000001M0300001
My keyboard is not responding to all characters when I type and I have to continually press some keys to get a result
  • 35 Answers
The keyboard might be dirty t the connecting part so the sensitivity is lessen. please clean it up using a swab or a hair blower
Posted on Mar 30, 2011
  • 391 Answers
Sometimes you may find certain keys of your laptop keyboard not working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are suppose to maintain your laptop keyboard by cleaning and lubricating it regularly.
INSTRUCTIONS
  1. To start with, take out each key out from the laptop keyboard. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
  2. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
  3. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
  4. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
  5. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
  6. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
  7. Once you have cleaned and lubricated all the parts, carefully reassemble the laptop keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
  8. goodluck
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Tip
    Some letter key is not working on keyboard???
    if any of the key on the keyboard is not working, you can use an alternate for time being. This is regarding ASCII. There are ASCII codes for every character on the keyboard. A - 65,B - 66........... So on a - 97, b - 98...........So on
    Use these codes by pressing and holding Alt key on the keyboard. In order to type b character. Press and hold Alt key and type 66 from the numpad at the right side of the keyboard.
    on Apr 17, 2010 | Computers & Internet
    How to get the sterling pound symbol in K120 logitech keyboard
    Entering the following keystroke combination will result in the Pound Sterling sign being displayed:
    While holding down the ALT key, enter 0163 (ALT+0163).
    This is known ASCII Code. (Pronounced Ask-key.)
    A complete list of all 256 character codes is available at http://www.ascii-code.com/ .
    All manner of Latin-based characters are available. Check it out.
    To use any ASCII Code, choose the "HTML Number" and substitute "ALT+0" for "&#".
    In this case, the HTML Number is &#163, therefore when entering text, type ALT+0163 (NOTE: "ALT+" means "While holding down the ALT key, press and release each of the four digits in sequence, then release the ALT key.)
    Hope this helps.
    Sep 02, 2014 | Logitech K120 USB Keyboard
    S60e 3etters 6n 0y 2eyb6ard res43t 5n the wr6ng character. Th5s -r6b3e0 sh6wed 4- wee2s after -4rchase. n5t5a33y 5t was w6r25ng f5ne
    Hi wa33ban2hart
    Question: "Some letters on my keyboard result in the wrong character. This problem showed up weeks after purchase. Initially it was working fine".
    You've done unbelievably well to type an error-free, letter-perfect question, despite the character confusion.
    This is a very strange problem to have on a desktop keyboard (Dynex Keyboard and Mouse), since the way to achieve the above sentence as you have written it, is to use the Fn and NumLk keys, on a laptop keyboard, to enable buttons with multiple functions to print their alternative characters designated to them.
    Desktop keyboards do not usually have Fn keys and the NumLk key on a desktop keyboard locks and unlocks the Number Pad on the right of the keyboard, which usually has no alternative letter values on its keys.
    Solution: Press and hold the Fn (Function) key on your keyboard > press the NumLk (Number Lock) key (usually F10, F11 or F12) > release both keys > test keys J, K, L, U, I, O etc. again.
    That should resolve your problem.
    I hope this helps.
    If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
    This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
    If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
    Thanks for using FixYa
    Sep 11, 2011 | Dynex Keyboard and Mouse
    Sony Vaio Laptop only typing numbers 1234567890
    see on your kebord Fn, + num pad, then will type all corect
    May 28, 2011 | Computers & Internet
    2 letters get typed while pressing one key for some characters. There are some keys in pairs in which if i type any of the key, both the letters gets typed. i.e. if I type s, sd gets typed or evens if I...
    try other keyboard if the problem don't appear that's hardware problem, may be the rubber under the key responding each other, it is easy to open the keyboard casing then you can check the problem inside
    May 13, 2010 | Computers & Internet
    Cursor won't stay where I move it with the mouse
    Hi, your first problem (and possibly second problem) sounds like it's the "Insert" function on your keyboard. I've seen this a lot. Find the Insert key on your keyboard. It's normally off to the right side with the Home, End, Page Up, and Page Down keys. When you have the problem, press the Insert key and then keep typing. It should toggle between the cursor moving with typing, and not. If this was helpful, please rate my response. Thanks!
    May 15, 2009 | Dell Latitude D820 Notebook
    Toshiba tecra s2 keyboard starts skipping typed characters and stalling
    there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
    pls remove the key board cap carefully and clean
    Apr 29, 2017 | Toshiba Tecra S2 Notebook
    Datalogic Heron D130 (Barcode Reader) Header setup
    Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
    Mar 19, 2007 | Datalogic Heron D130 Handheld Barcode...
    Computers & Internet Logo
    228 people viewed this question
    Top Microsoft Computers & Internet Experts
    Ekse
    ThaMp3Doctor
    ThaMp3Doctor
    Scoee Scoffer
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
