Tip & How-To about Cobra 29 LTD CB Radio
One of the few things i come across relating to the 11mtr band is operators setting vswr on low ground which will can totally give false readings sometimes .The best method while matching your antenna to your rig ,is to go to the highest peak possible ,Mountain etc and do all your settings from there you will be suprised the difference and outcome of this method .one instance ,ever set your base antenna on a we say a 10ft mast get a 1.1 match and then rise it 40ft suddenly the readings have risen to 2 or even 3 for that matter so if you take my advise you will allways have a low vswr hence better performance and long lasting communication from your rig ,note iff your vswr is high you can after prolonged use do damage to the final transistors so save yourself time and money and set as i have discribed
goodluck
