Fisher Price Fisher-Price Fisher Smart Cycle Extreme Logo
Posted on Mar 30, 2011
Pluged in smart cycle in t.v. and smart cycle will not come on please help
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1052
Points
I had a similar issue. My Smart Cycle worked for a while, then it progressively became more and more temperamental, failing at unusual times, not turning on consistently, then finally quit powering on entirely. Turns out there was dirt & grime (maybe a little corrosion) on the game cartridge and plug. The solution -- clean with Windex and q-tips.
Here's the post that led me to that conclusion:
http://www.fixya.com/support/t317354-smart_cycle_fisher_price
And more on cleaning the cartridges and console plugs in general:
http://blog.pricecharting.com/2012/03/how-to-clean-video-games-consoles-with.html
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 30, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
3750
Points
15
If you have a TV with a "Game" setting like we do, set it to that and see if it helps (on our Sylvania TV it is a button on the remote that says "Game". Good luck!
2answers
My sharp smart tv has lines no picture you turn it on you have a picture and then it goes to blue red green white lines no picture
please power cycle your smart tv. If this does not work, please remove all accessories and power cycle again. If still not working, you can factory reset the tv next.
Thank you.
Samsung dishwasher not finishing was cycle flashing smart auto and normal lights at same time and not draining out water please help
http://www.appliancepartspros.com/diy-story-error-code-over-fill-flashing-smart-auto-diy916377.html
I turn on smart cycle extreme and only half screen comes on with green color, but it doesn't start the program. Please help!
Clean the cartridge connection with Isopropyl alcohol. Also clean where the cartridge is inserted (an old toothbrush works the best). This corrected the issue for me.
1helpful
"smart cycle extreme" electrical cord
Here you go. The cord is the last item on the list. Hope it works out!
https://store.mattel.com/ProductParts.aspx?cat=139&sec=8713&productid=N9628&tx=103
The dishwasher runs completely throught its cycle. It appears the pump is not pumping water up on the dishes. Help please!
somtimes the holes on the sprayers will get pluged up, they can be removed and rinsed out usually by removing a nut or cap in the center of the sprayer. let me know.
Oct 17, 2009 • Dishwashers
I have a fisher price smart cycle and can not find where the 9 volt battery goes please help
The smart cycle, according to fisher price, uses 4 d cell batteries, no 9v
Jul 17, 2009 • Toys
2answers
Smart Cycle Pedal
The pedal has a reverse thread. So screw it on by turning counter clockwise. Hope this help.
Jun 19, 2009 • Toys
The conditioner drwaer fills with water after each cycle and the machine leaaks during each cycle
Check for pluged drain to washer ,check fill hoses for tighten fittings and good washer inside. (seal). The conditioner container may have a valve that has gone bad or pluged up. To much conditioner can plug this part up, Should check with a appliance repairman. If this is electrical, he should do the job for safety. Hope this might be of some help.
Top Fisher Price Toys Experts
ADMIN Andrew
ADMIN Andrew
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
