Delta Luv Delta - Baby Products 5-in-1 Crib Logo
Posted on Mar 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a delta lov crib model# 4925-2 and i have set it up but i cant seem to get the bottom board to fit so it can support the mattress am i missing something? p.s its already been used and should i be worried about the recall?
Joe A
Level 2:
  • Expert 396 Answers
  • Posted on Mar 30, 2011
Joe  A
Expert
Level 2:
Answers
396
Questions
0
Helped
263676
Points
826
It sounds like you have the mattress support rails in upside down. The rails (2) have 2 nubs on each end that attach them to the left and right side of the crib. They look like what you would see on an adults bed that run the length from the head to the footboard. If installed upside down they dont work. There should be 2 swivel tabs on each rail. These face up. The mattress support fits into the very top of the rails and the swivels turn to just sit over the top of the support board and keep it in place. You can go to Delta's site and check for the recall. It is a FREE easy fix. Just plug in your model number and sometimes date of manufacture. They will send you the kit and you are now safe and secure. Here is a link to Delta to check. And as far as worried, it is your child's safety, check it.
Delta Recall Checker
What are the Assembly instructions delta Princess bows & laces 4 in 1 crib?
Delta Cribs manufacturer puts the conversion instructions on the bottom side of the flat board that fits under the mattress. Remove the mattress, flip over the flat board, and the instructions are there!
13helpful
2answers
I have a Delta Luv Crib Model 4885, Order No. W24255 Date Nov. 2004. Is there a recall on this crib?
Luckily I didn't see your model listed in Delta's Crib Recall. Below is link to Delta's website and a list of all Delta cribs recalled.
http://www.deltacribrecall.com/
If this information is helpful, I would really appreciate a "thumbs up" rating!!
Delta cribs manufactured in Taiwan or Indonesia, with the “Crib Trigger Lock with Safety Peg” drop side hardware design, numbers:
4320, 4340, 4500, 4520, 4530, 4532, 4540, 4542, 4550, 4551, 4580, 4600, 4620, 4624 (production dates 01/06 thru 11/07), 4640, 4660, 4720, 4735, 4742, 4750 (production dates 01/95 thru 12/00), 4760 4770, 4780, 4790, 4820, 4840, 4850, 4860, 4880, 4890, 4892, 4900, 4910, 4920, 4925-2, 4925-6, 4930, 4940, 4943, 4944, 4947, 4948, 4949, 4950, 4958, 4963, 4968, 4969, 4980.
Delta drop side cribs manufactured in China through 2005, with the “Crib Trigger Lock with Spring Peg” drop side hardware design, numbers:
4340, 4343, 4520, 4600, 4620, 4624, 4625, 4629, 4660, 4665, 4720, 4750, 4751, 4850, 4855, 4857, 4880, 4920, 4925-2, 4925-2B, 4925-6, 4980, and 8605.
Need instructions for model # 4925-2
This model has been recalled. Follow the link below for the FREE replacement part order form... They will provide instructions in the package.
http://www.cribrecallcenter.com/cinfo.asp?recall=2&co=1&m=4925-2&p=90002
If this information was helpful, please take a moment to provide a "thumbs up" rating. Thank you!
2helpful
Is Delta Luv Crib 4980 built 12/3/03 on recall list
Hello Shohola107,
I found this recall list. I did see your model listed. Here is the list.
You can also check out this website. http://www.deltacribrecall.com/recalled_products.asp
Thank you
Was the Delta Luv Duchess crib- model number 4925-2t on a recall list?
You can look up the recall list for Delta cribs at the cpsc.gov website. You can call Products America at 800-205-9642 or 800-772-1041. We offer a wide verity of hardware and instructions for many cribs.
I have a crib it is a delta lov crib the model # 4925-2t is there a recall on it
Yes, Follow the link below for Delta replacement part order form.
If this information was helpful, I'd appreciate a "thumbs up" rating.
http://www.cribrecallcenter.com/step3.asp?recall=2&co=1&m=4925-2&p=90002
Need Replacement Part # 4 X H Crib Lock for Delta Lov Crib Model 4720
OUR DELTA 5 IN 1 IS MISSING THE RAIL GUIDE 4 X H CRIV LOCK AND #10 DOWELS AND NO INSTRUCTIONAL GUIDE HELP??
MZ Q
I cant find the rails to convert my crib into a bed.
Delta Childern's Products has a very similar product called the Canton Crib (discounted)
I understand Simplicity is out of business, but I would try Delta Childern's Products Customer Service (AT YOUR OWN RISK) :
Monday-Friday 9am-5pm EST.
(800) 377-3777 extension 6221, or call
(212) 645-9033
Fax: (212) 645-9032
FYI: Many cribs may look similar, however their construction and hardware systems are different. Serious injury or death can occur if the incorrect hardware is used on a crib. Please ensure you actually have a Delta crib. Our cribs use a mattress board and not a metal frame. Our name Delta Enterprise or Delta Children’s Products can be found on the instruction sheet that is glued on the mattress board.
1helpful
Need Instructions For Delta Luv 3-in-1 crib Model No.4580. Trying To Convert To Toddler Bed.
I have the same crib and the instructions are on the bottom of the mattress board. Mine states to remove one side to make it into toddler bed.
2answers
I need to know how to convert it to a toddler bed
There should have been an extra board with the crib.
My sister-in-law swears her's didn't come with it, but our's did.
You have to remove the sliding front side, along with the metal rails that hold the rail. You''ll see a hole on each end. 2 long screws hold the board on.
Top Delta Luv Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Delta Luv Baby Gear Expert? Answer questions, earn points and help others
