Question about Samsung UE32B6000 32" HDTV-Ready OLED TV
SAMSUNG UE32B6000 have problem with conecting ,it say weak signal,or no signal just blank screen, where do i start,
    Guru:
  • 276 Answers
If you just have over-the-air signals from local broadcast stations, you need a good VHF/UHF antenna connected to the RF input jack on the TV in order to get reception. If you have access to cable TV or satellite, you need to connect the box or receiver set-top-box to the TV using a HDMI cable. You need to select on the TV using the remote, (press the MENU button) setup for tuning channels. Do a scan after setting to AIR or CABLE so the TV picks up all available channels you can get. Once this is done you can change channels and see TV. If you reply back with specifics, I can help more...
Posted on Mar 29, 2011
6ya staff
SOURCE:
I have a SAMSUNG 58" 1080p Plasma HDTV FP-T5884. I can still switch the TV on but the screen shows pink bars no mater which source is selected. This video from a guy on youtube shows exactly the same on...
That is a typical case of poor/weak signal getting to the display via the FFC, either is a poor (or NO) contact problem, or a defective FFC.Look for the Flat Film Cable looking similar to the one in the picture, and make sure no pinching/broken traces. And/or confirm the conection at each side. Good Luck!
Mar 30, 2015 | Samsung Televison & Video
Weak or no signal
Either the connector on the set is bad or something is burned out. Try connecting to a tv or ext antenna and see what happens.
Apr 01, 2014 | Samsung Televison & Video
The pictures on my screen are a pinkish color on all channels
hi,
Go to the picture menu and adjust Tint setting according to your preference.
ok
Jun 09, 2011 | Samsung UE32B6000 32" HDTV-Ready OLED TV
What can I do to fix the flipping of the screen from snow to prog
the tuner is getting a weak signal and that is why the vertical sync signal is weak and the picture is rolling .check the cable on the back
May 23, 2009 | Samsung Televison & Video
Signal interruptions on digital TV set
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
May 18, 2017 | Televison & Video
Weak signal showing on my l e d samsung haven't used it yet (new)
Try to double check the power cable is well connected if so you have to know that some screens come from the factory with some problem and in this case you have the right to replace it from the seller.
Dec 16, 2008 | Samsung LN-T4665F 46 in. LCD Television
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung UE32B6000 32" HDTV-Ready OLED TV Logo
274 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
