The instructions can be downloaded here:
http://www.kenwoodworld.com/Global/Instruction%20books%20%28User%20manuals%29/Juicers/56992iss2%20JE570%20multilingual.pdf
Hope this helps!
SOURCE: manual
Hi - You can download the manual from the link underlined in blue below:
je700 juicer
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Instruction manual for Waring Pro Juicer JEX 328
It is downloadable as a PDF from Waring's Canadian website:
http://www.waringproducts.ca/en/pdf/ibs/jex328c_en.pdf
SOURCE: Need instruction manual for a krups juicer
I do not have a manual or the tool that takes it apart.
SOURCE: given a kenwood je500 juicer
Hi all!! I also had same problem, but found that under the juicer there was a 'quality control' sticker hiding a small **** in the plastic. this **** is in line with the motor shaft which also has a slot in it. use a small thin screwdriver to hold the shaft while turning the basket anti-clockwise and remove. easy as that, will post a video later when I have a little time to do so.
Bruno Man
