Question about Delphi SKYFi3 XM Radio Receiver
Screen is blank
I can't get the receiver to turn on in the car or in the home docking station. Is there a way to check the battery and, if it's dead, to recharge it or replace it?
I just had the same problem, read about reset by holding volume up and mode/power button at the same time, held about 5 seconds and the unit powered up, good luck
Posted on Sep 22, 2008
  • dirthill Feb 21, 2011
    Tried it out of the cradle, but screen did not come on until I did put it in the cradle!
6ya staff
SOURCE:
Radio stopped working. Screen would go back and forth from dark to light blank. Unable to turn on or off. Had to remove battery from radio to stop the alternating sequence. Reinstalling battery and...
Either Battery is dead, not charged, or needs to be replaced. Try using another charger overnight and see if takes care of the problem. If not replace the battery. If you have a volt meter you can check the voltage on the battery and on the charger. Expected output voltage is marked on the battery and the charger. You can pick up a cheat volt meter at your local auto parts or hardware store and will help you diagnose your problems.
Nov 23, 2010 | Delphi MyFi Satellite Radio Receiver
My Delphi XM2GO MyFi has stopped transmitting to an FM station on a house radio. Is it repairable? If so, is there a facility in the Cleveland, OH area where I can take it?
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
Aug 09, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Doesnt work
are u reset pressing mode and volume buton at the same time?
Dec 18, 2009 | Delphi SKYFi3 XM Radio Receiver
No battery power
You can set the Battery options from the Preferences Get to the screen which asks if you want o turn off, an dthen accept. The next will ask if unit should be turned off every time power is interrupted. Select NO
Jun 19, 2008 | Tomtom GO 910 GPS Receiver
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
How did this happen?
sorry man but i think a new battery is the way to go. i had the same problem and a new battery fixed it right up. -Nascar
Apr 10, 2007 | SanDisk Sansa e260 MP3 Player
Delphi SKYFi3 XM Radio Receiver Logo
317 people viewed this question
Top Delphi Audio Players & Recorders Experts
Larry Tezekjian
Larry Tezekjian
Colin Stickland
Colin Stickland
Ekse
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
