Dryers Logo
Posted on Mar 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have model ye226lv. I have replaced the belt, rollers and guide. The dryer is still making a noise which seems to be coming from the blower area. The squirrel cage will rotate by hand without the motor turning. It does rotate when you turn the drum. Is there a key that is broken on the plastic part?
jerry earick
Level 2:
New Friend:
  • Expert 96 Answers
  • Posted on Mar 29, 2011
jerry earick
Expert
Level 2:
New Friend:
Answers
96
Questions
Helped
17072
Points
191
Your blower wheel is stripped out. Replace
1helpful
My dryer WGD96HEAW1 makes vibrating and grinding noise after heats up, not in the beginning when turned on.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Feb 28, 2016 • Dryers
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
How do I fix my whirlpool cabrio dryer model wed6200swi so that it stps the noisy squealing sound when it runs?
DRYER MAKES NOISES.
The blower:
The bearings:
My Kenmore dryer model #110.9757 is making a loud noise
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Oct 07, 2014 • Dryers
My dryer MAKES A lOUD THUMPING NOISE IN THE DRUM. BELTS ARE NOT BROKE
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 05, 2014 • Dryers
What could make a noise when drum tumbles on Fisher Paykel top loading dryer, Model DEGX2?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
When cloths are in the dryer, drum squeaks every time it goes around. Is there a way to grease or oil, or does it need a belt? It is model no 417.94702300.
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 28, 2014 • Dryers
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Drum Bearing
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 • Dryers
3helpful
2answers
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
7helpful
2answers
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Top Magic Chef Dryers Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Don A
Don A
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
