Error code E6H on your AEG Lavamat washing machine typically indicates a problem with the heating system. It may mean that there is a problem with the heating element, the temperature sensor, or the control board. It's best to refer to the manual for your specific model for the exact meaning of the error code and for further instructions on how to resolve the issue.
If you are unable to resolve the issue yourself, it is recommended that you contact a professional repair service for assistance. Attempting to repair a washing machine can be dangerous and may void your warranty if not done properly.
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
what this indicate simple mean that there has been an over flow of water into the panel(that is power control ) or there has been a loos of wire from the connection of the panel connected to one of the button .
what you are to do to fix up this problem is to unscrew (open) the washer from the stroll then clean up the the panel very well with out disconnecting any wire from it position or
from the loos of wire trace the wire down to the control button connected to the panel and fix up the loos wire back to is position (on the control button)
please this with care with out any form of this connection on the wires.
