If I use my MacBook Pro to print, and it is the only computer on the network, and turned on and logged in, then the printer functions perfectly. But if anyone on our home network starts a PC with Windows 10 and logs in, in a matter of seconds the lights begin to flash. I think this is not an HP issue but rather a Windows (i.e. Micro$oft) issue that they need to address. They always push out updates without fully testing them and then wait while we the end users do their QA work for them. You should complain to Micro$oft for a fix. They need to get tons of complaints before they will even look at the issue without blaming HP or the user themselves.
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
