Dell PowerEdge 1800 Server Logo
Posted on Mar 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell PE 1800 showed one SCSI 73G non critical state on a RAID 5 array of 3 disks. Shutdown the server, removed the SCSI disk and booted, server booted but continous beep sound, trying to rebuild the array with the same disk, still beep sound is not going. please help
Hans Pedersen
Level 3:
  • Dell Master 3,606 Answers
  • Posted on Mar 28, 2011
Hans Pedersen
Dell Master
Level 3:
Answers
3606
Questions
0
Helped
2232041
Points
8683
Hi, try to renew the drivers and firmware from here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=PWE_1800&os=WNET&osl=en&catid=&impid=
Continuous beep related to ram ,try to remove ram and insert it, and if u still get beep change your ram.
Continious beeb sound is ram or cpu failure. Is the cpu fan spinning ??
If not the cpu is over heating.
Try to remove the ram modules and clean the contact points
with a piece of paper. Be very carefull when you do that !!!!!
And blow the dust out of your server, with a high pressure can.
Hope this was helpfull.
A disk read error has occurred when booting a Dell PowerEdge 2950. Passes all diagnostics. Will run chkdsk from CD. Raid battery was degraded at last reboot but all disks showed to be fine. Raid 1
what OS?
what disk?
no raid card stated, no array stated, no type of array stated.
One can put 100s of RAID cards in this server.
both raid cards or HBA cards,(forJBOD)
i can fix any server, but first need to know what is in the box first
you meant the boot disk has errors, right,? boot.
that would tell me the disk IS BAD.
but if and ARRAY , that means you must run SMART tests
on the disks, 1 by 1 to find the bad disk.
if smart shows its bad, or weak its for sure BAD.
on real servers. the server sends you email, (set up right)
telling you disk 3 in a RAID 6 is bad, replace it now.
are you running hardware or software raid, or HBA or
fake raid cards, (4 classes there.!)
the base system new has.
4 port SAS 5/i integrated SAS controller (no RAID_
and optional, from DELL , news.
Optional PERC 5/i integrated SAS/SATA daughtercard controller with 256MB cache,
PERC 4e/DC, PERC 5/e adapter
or any of 1000s of other aftermarket cards there.
I run LSI 9361s (with MSM appl loaded)
this card will tell you what disk failed every time no kidding.
so will the PERCs setup correctly
the PERCs and my LSI and my HP raids
all have installed monitors for the RAID ,a program that runs full time all the time, and reports errors , many ways,
did you load that first and use it? seems not.
as no mention of SMART at all.
good luck.
Im not sure the names on DELL , MSM like software.
ah its OSA
never run a PERC lacking this APP. or you can not keep the server on line,.
http://www.dell.com/support/search/us/en/04#q=Dell%20OpenManage%20Server%20Administrator&sort=relevancy&f:langFacet=[en]
I have a Dell Poweredge 1800 with 4 Cheetah 10K.7 Ultra U320 SCSI Drives which are supposed to be mirroring each other in case of failure of one hard drive the exact same thing is on the others. Drives 1...
hi!
This is a quite serious matter to be solved. The information you have provided is not enough at all.
What you have to include in here:
  1. First, Be precise. Don't assume.
  2. How did you recognized the failure. Which indicators or POST/BIOS/RAID BIOS reported you the errors? Was it from the OpenManageSA?
  3. Please specify the Hardware Controller model and manufacturer with the version (RAID controller).
  4. Which Operating System do you run (or ran)?
  5. Are these disks Hot Swappable?
  6. Have you used hardware RAID controller or software RAID? Provided by OS.
  7. Do you have Dell OpenManage Server Administrator?
  8. How do you describe the RAID configuration? Are you sure that Disk 1 and 4 are mirrored to 2 and 3? You must be precise. Because raids can be used in many ways. You can combine any two disks and mirror them to any two disks. Even though it prevents hard drive failures, if your OS had an issue Mirrors may not be an option to recover it.
  9. That message is a Warning Message. However Drive Roaming has completed. You don't need to worry about that.
  10. If your BIOS has associated firmware controllers you could rebuild the array. But you may have to add new disks to replace others. You may need to update the firmware if necessary.
  11. Then if you plan to use disk 2 and 3, you have to position them to 1 and 4. Then try to rebuild the array. But you may have to have Controller Drive installed on the disk. That varies from type to type. So I cannot say exactly. However if the mirroring of the OS is done to one disk, that disk would be enough. But you have to be certain. Reconfiguring should be done using both the disks replaced if you do not know anything about the configuration.
  12. Check BOOT ORDER. Change it if necessary. If disks fail again check one by one and repair them using a separate machine.
  13. Use Dell Software (OpenManage Server Administrator, if its the one available). Rebuild and or Resync the array.
  14. If boot record errors occur, you have to boot from CD/DVD and repair the Boot Record and/or MBR.
  15. If you need any other issue like BSOD, please write them down. Make sure the OS is not corrupted. If you backed up the System Status, restore it in such a case. Do an In-place Upgrade otherwise (will replace the OS files only, not data).
  16. Use the manuals for Dell Server and RAID Controller if you do not know how to use properly.
  17. If all the options are not working, you have to contact an engineer at Dell.
Feel free to contact again.
Thanks for using Fixya!
-Lasitha
I have dell 4600 pe serveri want to install Server2003 os i have configured raid 1 on the machine every thing is fine but! on boot process it display message no Boot Device Found Press F1 to continue F2...
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
1helpful
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Valid operating systems fro Power Edge 1800
During the Windows XP setup you will need to provide the RAID driver using a pre-formated floppy disk.
Windows will ask you if you want to provide additional drivers and give you the key combination to use to do that.
Upgrade IBM Xseries 346 Server
You can add drives to the array through the scsi management software, then you can extend any dynamic partitions that don't have the OS on them. I don't think you can extend the array if it contains the OS. You may need to use the disk management utility in windows to make the partitions 'dynamic disks' before you can extend the data partitions
SCSI BIOS not installed / ML150G2, exchanged mainboard, RAID
hi..
my guess is no but since i haven't dealt with this type of server i'm going to suggest you go to hp.
if you just goto hp.com and search on live chat and a link will come up.. they should be able to help unless it's too old since i'm not sure what generation we are on now..
good luck, hope this helps a little..d
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
