First, do not attempt to try to fix it right away. Unplug every cable and adapter, so you only have the xbox 360 console. Then, if a video game disc is still in there, take it out. Next, try to determine what your disc tray is stuck on, and try to remove it carefully. If these steps do not work, look at these articles. Manually eject your Xbox 360 console disc trayXbox Disc Drive Solution.
IMO Never Use a cleaning disc for Gaming consoles. Which Xbox 360 do you have? Is it the Older Model or newer one? You can Try Blowing into Your Xbox disc drive. Is your xbox up to date,you can unplug your xbox 360 and from the wall and the Xbox. Wait 25 Mins and Try again.
That might be something related to your Xbox 360 console itself or the disc you are trying to play on, so first have a look on the Xbox 360 game disc itself and check whether there is any kind of scratches or flaws on it.
If you find a scratch or a flaw on the disc that seems to be the reason and just to check it you can put any other game in your Xbox 360 console and try it once more, if the other game is working fine that definitely assures that it's a fault with the game disc & check on the scratched discs page on our web site for more information about the reason for this issue to occur.
In case there is no scratch or a flaw on the game disc try the following steps: 1- With no discs in the disc tray, go to the System section on the dashboard. 2- Select Console Settings. 3- Select Start Up. 4- Make sure it is set to Disc not dashboard. If it is set to dashboard, select Disc and try the game again. It should work. If is already set to disc or you tried setting it to Disc and still not working try the following steps: 1. Just clean the disc & put it back in your Xbox 360 console and see whether it's going to work again or not. 2. If it's still not working try also another discs to know whether it's an issue with the actual Xbox 360 console then or not. 3. If the other discs work fine you can try it then without the hard drive because it might also be something related to the hard drive. 4. If it is still not working so this game disc would be for sure faulty and you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "To play this disc, put it in an Xbox 360 console" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
about half of the game on the original xbox have a completely unrecognizable codec as opposed to the xbox 360 so there is'nt really any way to fix it sorry...
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Are you using a modded Xbox 360 console?, if not then the disc you are trying to play is probably a copied Xbox 360 disc which would not work on an original Xbox 360
