SOURCE: Philips GoGear 512mb
I'm not sure about the Memory Format Error, but you are going to need the software to not only recharge the player, but put music on it as well. To turn it on you have to hold down the play button until you see a little "Philips" logo pop up on it. I looked into downloading the upgrade to see if it could recharge that way, but it seems to be only what it says it is; an upgrade. I suggest you ask your husband's friend for the software disk.
SOURCE: Philips GoGear 2GB memory corruption
i have the same problem , my friend works on them said some how the info on the hard drive got ereased. maybe i had i to close to big speakers .
SOURCE: sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
SOURCE: I have A GoGear and have misplaced the cord where can I get it
Call Fox International - they officially replace all Philips mp3 player parts. 1-800-521-9861 - just give them your model #SA6045/37
-Tha Mp3 Doctor
SOURCE: philips gogear mp3 stuck on gogear screen
try putting it into recovery mode by holding the volume up while plugging it into the pc this might at least get the pc to see it also try it with a diffrent cable
