Refrigerators Logo
Posted on Mar 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY WINE REFRIG CLICKS ON AND OFF AND IS NOT COLD WHAT IS THE PROBLEM?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 247 Answers
  • Posted on Mar 27, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
247
Questions
0
Helped
70111
Points
574
Try to clean your condenser and chek your condenser fan if working replace if not
REFRIG WILL NOT GET COLD
Rev,
You will need to provide additional information (make, model, year, etc.). The easiest thing to check is the thermostat to see if it clicks when turned all the way clockwise or counter. If no, then suspect the thermostat.
Otherwise all we can suggest is to contact an authorized service center.
1helpful
3answers
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 • Furniture
2answers
What are best dates to drink red wine?
There is no magic date. Just make sure to chill it for a hour before drinking. I know it sounds weird but that is how it is done. For white wine and it's been in the refrig. you need to let it sit a hour before drinking. Most folks drink white wine too cold and red wine too warm.
Uline wine refrigerator won't get cold
how old is it thay usely last a year or so set it tovery cold
5helpful
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Amps
building codes dictate how an electrician wires your house for appliances. your owners manual does recomend a dedicated circuit for your appliance.
Temp too high
lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
