We don't have the manual, but Metz does:
45CL-1 NC
45CL-1 NiMH
SOURCE: Metz 45 ct5 flash battery pack wiring diagram
You can rig that fella up for a better power.
[email protected]
SOURCE: AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Regards,
Neil
SOURCE: metz flash 45 CT3 compatible with nikon D70
Call Nikon direct in Melville, NY or go to NIKONUSA.COM
SOURCE: Metz 45 CT 1
I had that same problem also, but mines was temporarly. Ik think the condensor inside the Metz has to regeneratie (recover) itself by using with a full charged fresh batteries. The high freq. sound is normal. (although not to loud) after a 5 MINUTES the orange bulb should light up. How more u used how better the start-up time. My old Metz start-up time was around 40 sec. and now ot is within 7 sec.
SOURCE: Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
