Hello CODE INPUT SETTING: You will need the list of codes to manually select and input the correct codes to your specific device. 1. Turn on the device that you want to set. 2. Look for the brand name under the specific device listing provided. 3. Aim the remote control at the device and press down and hold CODE SEARCH button for at least 3 seconds until the red LED lights up solid red. 4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red. 5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice that each number that you press, the LED will blink once. After you have entered the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. (NOTE: If the code entered was not compatible, the red LED will flash several times. You will then need to repeat Step 3. You have 30 seconds to enter a code.) 6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying to program powers off, then you have found the correct code. If the device does not power off, then you will need to repeat the process again from Step 3, using another 3-digit code. CODE SEARCH SETTING: This is an alternative method to programming your device without using the code list. The remote control will scroll through the list of codes to identify the correct code for your device. 1. Turn on the device that you want to set. 2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red. 3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red. 4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note LED will blink once each time you press ON/OFF button)
Code for Admiral TV with Innovage remote control are:
001,173
7. Make a note of the 3-digit code for future use.
5. Once this occurs, press ENTER button to store the code and the LED light will turn off
