First of all, you must check to make sure that the door is closing properly before you run it, and that nothing is sticking out, or trailing out of the door.
secondly you must never open the door during the running of the dishwasher.
check to make sure the drainage is clear of protrusions. use special dishwasher cleaning salt if you need to. to do that, you need to obtain the special salt and run the dishwasher empty, it cleans away all the junk blocking the drain.
additionally, the connections to and from your dishwasher could be faulty and or leaking. check the input and output water line connections on the dishwasher and their other ends as well.
For the LD error please check for the following:
Note: Do NOT add any additional detergent. This will remove much of the remaining detergent held in the fabric. This step may have to be repeated to remove all the detergent.
