How to clear and avoid paper jams
Follow
these instructions to remove and/or avoid paper jams and misfeeds in
your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
NOTE:
Check inside the printer to ensure that all the paper is removed. Any
small pieces of paper left in the printer will continue to cause paper
jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
Check paper loading
Remove each page as it is printed
Adjust the paper guides
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
Check media loading
• In Windows XP (default Stamy Lexmark 4600 printer has a paper jam. do not - pattlnk_10282008_1829-right-arrow.gifoads/images/pattlnk_10282008_1829-right-arrow.gif" almy Lexmark 4600 printer has a paper jam. do not - pattlnk_10282008_1829-right-arrow.gifgif" class="h_mi" /> Printers and Faxes.
• In Windows XP (Classic Start menu): Start Printers and Faxes.
• In Windows Vista (default Start Menu): Control Panel Printers (under Hardware and Sound).
• In Windows Vista (Classic Start menu): Settings Printers.
• Make sure no check mark appears next to Pause Printing.
If a check mark does not appear next to Set As Default Printer, you
must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more my Lexmark 4600 printer has a paper jam. do not - pattlnk_10282008_1829-right-arrow.gifer paper jams
Review banner printing checklist
Regards,
Ron
