I'm trying to connect a sony blueray dvd player with builtin wifi. The set up calls for me to push the wps button on my wbr2310 router, but i cannot find the button, I dont think it exists What can I do
Phones do not usually have a WPS button; they often have an option to use the WPS button during Wi-Fi setup. Your wireless router may have the WPS button; check the manual or look at the router for the button location. To connect the phone to a router with a WPS button, go to Settings (from All Apps) and choose Wi-Fi. Make sure that the slider is set to On. Then tap on the icon with three dots in a black rectangle. Choose the Advanced option. Tap the WPS Push Button option and then push the WPS button on the router.
read the manual on your router?>
only that matters, , WPS varies by makers.
no router stated by you, are you at home.?
lost the router settings. ?
you can go into the the router, and set it up right.
like this.
SSID = fido10 (dog or cats name unique to you)
WPA (or wpa/wpa2) best. encryption.
pass phrase. (use a good pw here, so hackers cant hack it)
when write that down on paper.
now all you own, cell, tv, computers, and all wifi device work.
next time post router name and model.
like, CISCO, RV-320 or ?
then go to their web site, and read your manual
if your ISP owns the router ,not you then the only answer is
ask you ISP for this information
in most case, push the WPS button, the for a time limit
you can connect with no credentials. then it times out.
Usually you select the wifi network, tap Connect and then you're prompted for the password. I've never tried it, but if you pressed WPS on the router just before tapping Connect, maybe WPS would work.
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Ok firstly let me just state that the button in question is a "WPS" button and not all routers have these. Your sony dvd should have several methods to connect to a network please look these up in the manual and try a different method thanks
login to your 2wire router using a computer that is connected , open a browser and type 192.168.1.254 on the address bar, once logged in look for wireless setting you'll find WPS setting /button click on that then push the WPS on your bluray player this needs to be done within a few seconds for the router and the bluray player to pair.
The WPS button is used to configure a wifi connection with other devices that also have a WPS button. To use it you press the WPS button on the router then on the device you are trying to get access on and then both will be automatically configured.
If your wireless router was setup using the default configuration, the password, also called a security key should be on the bottom of the router. Alternatively you should be able to specify on your ipad that you want to connect using WPS, and your router will have a WPS button on it. Pushing it for 2-3 seconds would allow your ipad to connect without needing the password. You should be able to google "connecting ipad to wifi using WPS" and if necessary include your router model to get specifics about the location of the WPS button on your router.
CALL YOUR ISP FIRST. wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
