Nokia N73 Cellular Phone Logo
Posted on Mar 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
N73 camera hardware failure restart camera - Nokia N73 Cellular Phone
Level 3:
  • Nokia Master 17,130 Answers
  • Posted on Mar 26, 2011
Nokia Master
Level 3:
Answers
17130
Questions
0
Helped
3635295
Points
52372
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation.
try and format to confirm if this helps to resolve the issue. check this link
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
4 Related Answers
Anonymous
  • 495 Answers
  • Posted on May 22, 2009
SOURCE: n70 camera shows hardware failure restart camera problem
cameras in n70 has got two regulators, one under the back camera and the other is 2.8v down at the back called n1470 on oreginal nokia schematics,
check those both regulatores and your problem is solved .
Anonymous
  • Posted on Jan 16, 2009
SOURCE: nokia n73 (cannot open the camera even the video)
nokia n73 camera,video,bluethooth,is not working
Anonymous
  • 252 Answers
  • Posted on Sep 23, 2010
SOURCE: i have nokia n73 it's
this is due to the front camera's error connection.contact a hardware expert and fix it.
Anonymous
  • Posted on Nov 10, 2010
SOURCE: nokia n73 front camera hardware failure
nokia n73 front camera hardware failure solutin
1helpful
2answers
When i start the camera of my nokia n73 i got the msg. Hardware failure : restart camera
2 reasonfor this problem
first one is software corrupted and second one is camera damaged
most probably first one is correct as the percentage is high, try after reset all option and if not done install/update your phone software.
3helpful
MY N73 BLUETOOTH CAN'T PERFORM BLUETOOTH OPERATION AND MY 73 CAMERA IS NOT WORKING WHEN I WANT 2 CAPTURE IT BRING OUT HARDWARE FAILURE PLS!!!!!!!!!!!! WHAT CAN I DO
update your phone's software and it will comletly remove this problem.because that problems occur due to the software fault.for more details feel free to contact me
6helpful
I have nokia n73 it's front camera shows hardware failure restart camera
1helpful
Hi Guys, when I use the front camara my nokia n73, I get the above message. hardware failure restart camera I've tried restoring the original phone settings but it hasn't made any difference. I'd...
Since, your cell is giving hadrware failure that means you have to get it serviced. There is a possibkility that either your front cam or IC on motherbioard has been stop functioning,,, SO get it serviced...
But I think that there could be a software corruption. So I advicesed that before getting it serviced, Update your cell software and check that whether there is a actual software or hardware problem.. Visit to the given link, to know software updation process...
http://www.fixya.com/support/r4743802-nokia_software_update_or_applications
Before updating dont forget to back up your phone memory including sms and contacts...
Hope this has helped you....
Please rate the answer...
Thanks....
50helpful
5answers
Nokia n73 front camera hardware failure
4helpful
Nokia n73 (cannot open the camera even the video)
10helpful
7answers
Hardware Failure: restart camera
Hi there!
I had this same problem, just format your memory card, and the problem will be solved, but remember it will erase all your datas in your memory card, so you better have a back-up somewhere. I hope it will work for you.
6helpful
2answers
How to connect celphoone camera to pc as webcam on yahoo chat
go to www.motvik.com and in there is a program called wwigo. That is the program you are looking for.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
