2008 Chrysler Sebring Convertible Logo
Posted on Mar 26, 2011
2011 freightliner Cascadia with DD15. Fault code EEC 61 comes on. What does this mewnijju
  • 3 more comments
  • Anonymous Mar 15, 2014
    why doesn't 2010 freightliner cascadia come equipped with a anual fan switch?
  • Anonymous Mar 18, 2014
    How do i change headlight bulb on 2012 freightliner cascadia?
  • Anonymous Mar 22, 2014
    what does a eec 61 mean on a freightliner casecade 2013 semi truck
  • Constance Feb 10, 2019
    How to remove arrow in the freightliner
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Mar 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
13246
Points
49
BEFORE CONTECT ME DONT WORRY ABOUT IT 03452663007
mailoantonio
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 28, 2014
mailoantonio
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
9799
Points
What's the problem for freightliner cascadia EEC 61
Ryan Vercauteren
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Apr 10, 2015
Ryan Vercauteren
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
40708
Points
70
Check engine light on dd15 truck cascadia frightliner
You need to determine which sensor is causing the check engine light to come on. being a freightliner the most likely culprit is the engine oil pressure
I have a dd15 freghterliner 2011 with a fault code EEC 61 What do it mean
what engine has it go
if it is a GM detroit 60 series it is no 6 injector circuit board problem
heavy vehicle fault codes are specific to engine or transmission installed in what ever vehicle
take it to a service center for the engine make and have it properly diagnosed
2012 freightliner cascadia DD15 fault code ECU 1... prior to the fault code the engine bogged down really bad and solid yellow and check engine light come on.
an answer from just answers reports this
ecu 1 fault means the engine ECM has an internal fault and needs to be replaced
most of the time with this code it is not the ECM itself but usually a wiring problem going to the ECm
there should be 2 fuses for the ECM either next to the ecm in plastic covers by a starter or in a plastic box
check all wiring going to and from the engine and battery grounds
especially the grounds
check for wires rubbed through and loose terminals
take it to a service dealer for a proper diagnosis as it costs money wasting time trying to find the fault yourself as a truck standing still is not earning it's keep
Where can I find what the fault lites mean. on the dash of a Cascadia w/dd15
http://www.thetruckersreport.com/truckingindustryforum/freightliner-forum/240942-2010-cascadia-w-dd15-active-fault.html
2answers
List of diagnostic codes for 2012 frieghtliner cascadia engine type dd15
Igot a code Eng - # 1 5323 spin fail 13 on my 2014 Freightliner Cascade DD15 will not start up
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
