RCA 20F510TD 20 in. TV/DVD Combo Logo
Posted on Aug 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rca tv cant change password
My daughter messed with the remote and now it won't let me change the password. it will only let me put in 3 digits
  • mssheba Aug 29, 2008
    I do not have the orginal remote, but I have a universal remote, but every time i try and change the channel from the tv, it says that the FPA lock is on, and I don't know how to take it off, but if I use the universal remote, it only gets a couple of channels, but before I messed it up, I was able to get a lot of channels can you please help me.
Ric Shanahan
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Jan 12, 2013
Ric Shanahan
Expert
Level 2:
New Friend:
Answers
61
Questions
Helped
19458
Points
146
This default code (0,0,0,0) worked on my RCA 32LB45RQ as well. Thank you!
A
Anonymous
Use the default password of 0000 to bypass the unknown password....this is in the user guide for your model at rca
Cant put sylvania dwt1905 on game mode with rca universal remote
You can't select its game mode, with this remote control.
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
RCA TV
Your RCA TV is locked. You have to unlock this TV and enter a new password. To unlock it, try one among these ways:
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
I forgot my parenal control password on my RCA SDTV
2helpful
Need to change input, no remote
There is no way to change the input to this set without its remote control.
3helpful
2answers
I have an RCA F19421 Tv and can't take off the lock on my channels cause I dnt have the password.can u help me?
Hello
You must have its original remote control to unlock it. If you haven't one with you now, try to get a new one of just gather it from any of your friends or relatives who owns the same model number RCA tv; just to unlock your set. After unlock, you can use any other universal remote control. To unlock your RCA TV, just follow the proceedings given below. One amoung them will surely unlock your TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
I tried all the listed 3 digit codes for my tv and still cant get my rca remote to work
Hello wvl33:
Hopefully this page may help:
CLICK HERE:
It also might help if you put your TV brand and model number up so we can do a more thorough search for you.
How can i reset my rca tv my son put a password that he cant remember. I can't even get into the setting everything is blocked
If you forget your password, press and hold TV on the remote and the
MENU button on the television simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls
Good Luck please rate 4 thumbs up and please leave a testimonial
Cant change to any channel
Unknown password--chassis ITC008 with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
need RCA remote with clear button
4answers
Most of the stations are blocked!
Welcome to the wonderful world of the vchip. Making better babysitters through tecnology. From what I understand the control if placed in a ram and cannot be reset without the password. I would call RCA and talk with a tech there might be a generic unlock code like on the old playstations. You may have to prove you are the rightful owner and over the age of 18.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
