Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
I have a lenovo 3000 n100 laptop with black screen. I tested backlight with another computers inverter to narrow it down to either bulb or inverter board. So since screen lit up fine I assumed it was inverter and bought another off of ebay. When I hooked new board up same problem comes on for 1/4 second and turns off. Just wondering what else could it be or do I just have great luck and got a bad board? I appreciate any help anyone could give, thanks.
5 Suggested Answers
Anonymous
  • 24 Answers
SOURCE: Fingerprint reader software on lenovo 3000 n100
Hi jerseydeals,
I did a search and found an XP driver from the Lenovo site for your laptop's finger print reader, just follow the link below:
http://www-307.ibm.com/pc/support/site.wss/MIGR-63663.html
Also, the reader is controlled by the OmniPass software, you can check it out from http://www.softexinc.com who developed it and find the version for XP though theere are other software to which you could use that reader as well. Hope this helps
Cheers and best regards,
Posted on May 09, 2008
wings_it
wings_it
  • 141 Answers
try this link:
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=303747&machineind=303749&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&validate=true
enter your product details to download the soft you need cheers
Posted on Dec 24, 2008
Anonymous
  • 127 Answers
SOURCE: want to reinstall USB 2.0 integrated camera in lenovo 3000 N100
here you go.
for WinVista and for WinXP
other drivers are available here.
hope this helps, let us know.
Posted on Feb 09, 2009
Anonymous
My system refuses to detect camera device.... even though the camera is built in ( Lenovo 3000 N100) . Can anyone please help. btw it was working fine before.
Posted on Feb 24, 2009
RescueTechLA
RescueTechLA
  • 2653 Answers
SOURCE: Battery problem-plugged in, not charging. Lenovo
So when the battery is plugged in, it doesn't charge?
This is almost always a problem with a component not working correctly on the motherboard.
Sometimes it's the battery, but not usually.
There's not much you can do other than replace the motherboard.
You could try updating the bios, but it's a long shot.
Let me know if you have any other questions.
Best of luck!
Posted on Feb 26, 2009
Lenovo 3000 n100 webcam revert image
what do you mean revert? you mean inverted? you probably don't have the correct webcam drivers installed. go here: http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/63cn09ww.exe
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Feb 05, 2012 | Lenovo 3000 N100 Notebook
Lenovo 3000 n100 webcam mage flip
I AM NEW HERE... INSTALLED WIN 7 32-BIT ON LENOVO 3000 N100 BUT THE WEB CAM IMAGE IS REVERT...HOPE SOMEONE WILL HELP...WAS NOT ABEL TO FIND ANY USEFUL INFORMATION FROM THE ABOVE REPLIES/POSTS
Jan 10, 2012 | Lenovo 3000 N100 Notebook
I have Lenovo 300 N100 laptop, suddenly its screen goes dark after boot. At starting when i press Fn+F7 the LCD light comes for few seconds and then vanishes, now the duration of the light is even less...
The backlights in your monitor are part of the display panel itself and cannot be changed..
You may need to replace the entire display panel.
However, start by having the inverter which runs the display panel backlighting checked as the fault may lay in it rather then in the panel itself.
Now, you must be VERY careful when handling this inverter as it is more then capable of giving you a nasty electric shock.
To be safe, have the panel and the inverter checked by a professional.
NEVER handle an inverter that is connected to a supply rail..
The inverter is usually located inside the monitor housing of the laptop and care must be taken to open up the housing. Most housings are held together with formed plastic clips and you simply prise the fascia off the front very carefully. DO NOT apply any pressure to the display panel during this.
If the inverter is not in the monitor housing, then it will be under the keyboard and in this case, I would advise you take the laptop to a professional as replacing the wrong screw into the wrong hole can cause serious damage to the mainboard and destroy the laptop.
Mar 10, 2011 | Lenovo 3000 N100 0689 Notebook
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
Hi There, I've been experiencing the same setback as Kenneth. My lenovo 3000 flashed off and even if I boot it, the screen is still black.How ca I fix it?./ Ty
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 16, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My notebook screen 3000 n100 goes dark after few second
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 15, 2009 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 n100 notebook display problem
Appears the backlight for the LCD display has stopped working. This usually needs to be replaced by a professional unless you are electronically and mechanically savy.
Jul 10, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
190 people viewed this question
Top Lenovo Computers & Internet Experts
Ekse
Toby Lee
Toby Lee
Sunny Solanki
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
