I don't think a2 razor is a folding scooter.You should check it first.A3 is better than a2. The Ultimate Razor A3 Kick Scooter Review
SOURCE: Can't fold down a razor cruiser for storage, how do you do it?
There are two steps to release the handle for folding. Pressing the thumb lever is one step and the other is lifting the handle bracket up. The handle is held in place by two metal pins (one on each side of the handle bracket). The pins slip down into a notch on the scooters bottom bracket. If the lever won't push, you will need to spray some WD-40 or other lubricant on it as they do tend to rust. Once you have the thumb lever where it can be pressed down, you can then lift the handle out of the bottom bracket. This may be stuck as well so a light tap with a hammer may be necessary to release the handle.
SOURCE: Cannot unfold our Bratz Musical Stars Fold Scooter
Call MGA toll free 1 800 222 4685 and they will walk you through the procedure. You have you put one hand on the slanted bar with the yellow label on it and one hand on the foot board and push in and down at the same time. Push at the same angle as the slanted bar. I couldn't get ours open either so I called the company - Good Luck!
SOURCE: I cant fold the scooter down to fit into a suitcase
There are 3 things that can fold.
The handlebars collapse from the lever on top of the handle bar, that allows each handle to pull out.
The lever at the base of the handlebar allows it to retract.
And the lever at the base of the steering allows the body to fold against the steering shaft.
