Toshiba TEC B-SX4 Thermal Label Printer Logo
Posted on Mar 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer always showing error on we do not know how to set the sensor correctly
kong win chang
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert 142 Answers
  • Posted on Dec 09, 2013
kong win chang
Toshiba TEC Expert
Level 2:
New Friend:
Cheetah:
Answers
142
Questions
0
Helped
52936
Points
152
Power on with Feed and paused epressed and wait for message (1) diag ...
with feed advance to 5 sensor adjust.
place the backing under the sensor.
Depress pause so as to have transmissve V4.xx if not the case presse restart 5 seconds the value should change.
press pause to vlid the value.
Switch off and 5 seconds later on (Wait for the led to go off)
The transmissive sensor is set.
2answers
Konica minolta c6000 errors2221
• AC drive board (ACDB)
• Printer control board
(PRCB)
• 1st transfer pressure
release motor (M19)
• 1st transfer HP sensor
(PS15)n
Check the above items first the sensor and the motor the boards $$$$$$$$$$$$$$$
Canon ir 2570 error code 7356
The printer knows if it needs paper by a sensor. Usually this is is a light beam across the paper supply. Both ends, the light and the sensor can get covered in dust and may need to be cleaned
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
I have a Magicard Rio I keep getting the error message card jam error 02:12 yet there is no card jam if i put a card in the back it ejects it correctly help
Hello Colin,
I'm not sure how old your printer is, but I suspect this is caused by a loose connection on the front card sensor (especially if the error occurs when initialising). If there is a loose connection, the card sensor always shows as blocked (hence the error 02:12). I guess this is a Rio 2e and not a Rio 2 model.
Send us an email to;
[email protected]
Make sure you quote the printer's serial number in the email.
I can send you some detailed instructions for confirming this is the problem, and also suggestions for repairing the printer.
Regards,
MC.
1helpful
When trying to print and condiition and error lights keep coming on. also when pressing feed it feeds through more than one label and then shows the condition and error lights.
Most common cause for this is sensors not positioned correctly. Make sure that the white arrow on the top sensor is aligned with the bottom sensor. See you user manual.
Also check that the senor used is the correct one for the maedia (i.e. black mark or transmissive).
3helpful
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
2helpful
RIBBON ERRORS
Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
- The ribbon roll is not correctly fitted to the spindle.
- The sensors detecting the rotation are out of order or completetly filled with dust or grease.
In this case clean the sensors.
Another reason may be due to Direct thermal printing with a ribbon mounted.
2helpful
2answers
Estimated ink levels are incorrect
The simple solution is to buy the HP cartridges. Often times,.. MOST times, aftermarket ink cartridges and refill kits are an inferior product. The difference is not always noticeable right away, but almost always rears it's head in the end. This is usually due to the ink being of a different viscosity than the original ink. Which leads to sloppy prints, sensor errors, leaky or dead jets.
Personally I recommend everyone buy Laser printers. With prices where they are these days, there is no reason for anyone to buy an inkjet printer. Lasers will cost more up front, but are much cheaper per page and generally longer lasting.
Top Toshiba TEC Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
