SOURCE: oil level system
It may seem obvious but do not operate the engine with it overheating as this can lead to more trouble including a cracked engine block.
Low engine oil pressure is a problem because if it exists, the critical engine parts may not get lubricated properly and may fail. Since you have ruled out external leaks, here are some possibilities:
Clogged oil filter or obstruction in the system
Loose wire or faulty oil pressure or oil level sending switch/sensor.
Possible blown head gasket. This is a serious problem that might be accompanied by white or blue exhaust smoke and a burnt coolant or oil odor. Check for oil contamination with coolant. The dipstick may show a brown milky film/sludge or smell like burnt coolant indicating contamination.
Engine oil pump is possibly bad. This is a serious problem. It's usually time to swap out or rebuild the engine, particularly if it has many miles.
Possible but unlikely in this case is a problem with PCU (Power Control Unit) that runs the Information Center. PCU problems are often indicated by getting other unrelated errors on the info display or "DATE NOT AVAILABLE" for extended periods when you start the car.
You did not mention the Check Engine/Service Engine Soon light being on, but if so I would get the trouble codes read at the OBD II connector. The codes might indicate a sensor problem. Some auto stores do this for free. Either way, I would assume the worse case scenario (bad oil pump) and address it immediately. Unfortunately, due to the complex nature of the car, most things are not easy to diagnose and repair by the do-it-yourselfer. Hopefully though it is just a sensor but with a temperature rise, I would be careful.
Best of Luck!
SC442299
1996 Oldsmobile Aurora
4.0L DOHC 32V V8
Autobahn Option
SOURCE: 2003 Mercedes C180 Compressor AUTO BOX transmission oil check
The transmission fluid is not to be checked or touched unless there is a malfunction in the system and the fluid has to be drained to repair it. The transmission is sealed form the factory and the fluid lasts the lifetime of the unit.
SOURCE: 2000 Jeep Cherokee Transfer Case Leak
Clean the area off with a degreaser and watch it. If it is an input or output seal leaking, you unbolt the drive shaft going into the case, remove the nut that holds the u-joint flange on, pry the old seal out and tap the new seal in (be careful not to tap too hard or the seal will bend)
SOURCE: Where can I check the transmission fluid level on my Kia Rio 2001
On your trany u got a plug just like a transfercase on pick ups.. thats how u check the oil level..
