Hi, well to set a second voicemail up, please use the manuals supplied, as for setting up as usual, whenever I need to set a second one up, I always go to another phone, so that that phone defaults to the 2nd account, So setup one account as normal on phone one, go to phone two access 2nd line and setup voicemail for that one..This way each phone has it's own default, but each, well all phones now on the system can, actually, can then access each other... OK?
Also I think one has to organise a voice mail account with the service provider, and make sure that each line actually has a voicemail mail box assigned to it in the first place.
Some systems only allow ONE voicemail,as default. (sometimes others can be added)
service.us.panasonic.com/OPERMANPDF/KXDT333.PDF
http://www.telephonesystems.co.uk/Panasonic-KX-DT333-User-Manual-UK/Panasonic-KX-DT333-User-Manual.aspx
www.acutel.com/.../KX-DT333-343-346_Quick_Reference_Guide.pdf
Hi please find above your manuals,
Dial your extension. Wait for the greeting to say that you are at your
voice mailbox. This is also the "Quick Voice Mail Tutorial Set Up."
Follow the instructions provided in the tutorial. You will be asked to
enter your name (or company name), password and greeting. Write down the
password and keep it in a safe place.
Record other greetings, if needed. After the tutorial, you have an
option to add different messages for different situations. Press "311"
to change your general greeting. Use "312" to record a message for when
the line is busy. Dial "315" to record a temporary greeting for when you
are away for an extended period of time, such as vacation.
In addition, visit this link below and read the information on page 9. I think it will be of help.
http://service.us.panasonic.com/OPERMANPDF/KXDT333.PDF
Good luck.
I don't know my extension. While this is a business phone, it's used at home and we have two separate phone numbers: one reached using button 1 and one reached using button 2. Thus, I am having trouble setting up my voicemail even with your instructions.
I have time warner and there is no extension to my phone line. I just called in and found this out.
Basically we have two phone lines with dissimilar numbers. One can be accessed by default and the other, you must press the 2 button in order to use it. I need to setup voicemail on the second line.
While this is a business phone, it is used at home. We have two different lines with dissimilar numbers and no extensions. I would like to setup the second phone line's voicemail. The first phone line can be used by default and the second one by pressing button 2.
