No picture Just Sound
Hi
There are different possibilities in your case¸but what happened to me ...
The LCD Backligh is out , I mean the bulbs or neons of the screen BACKLIGH, you have to check either the lights itself or the driver circuit which supply the HV to operate it, usually its a separate small long PCB beside the TV main board .
You can try this trick , Keep all lights off in the room and bring a table lamp, preferred a white neon one and face it lighted on the top of the screen with the TV on , try watch a very dark but exact picture with the sound you are hearing. This is a way to be sure that it is LCD backlights problem when using an external light to illuminate the screen .
It worked for me ,Good luck
the television would start blinking whem
n first turned on,. Then it would go ahead after a few minutes, it would come on. Then, it started blinking faster after each time it was turned on, now it is completely black, but with sound.
