How do I set? I have used the instructions but nothing seems to work.
Norene
Well the stem should be pulled out, it could just be stuck but in order to adjust the time, you should pull it out.
if you want to, you may bring the catch to a watch repair specialist and have the stem cleaned to that if you need to set the time, it will be easy to adjust it.
be careful not to use anything sharp like a blade, you may risk remove the stem handle
You set it using the wheel pull it out , it should have two positions, one adjust time the other one date and chronograph, I see if I find full manual.
The stem does not pull out. I'm afraid to be too forceful with it.
Norene
The stem will not come out on the watch I'm afraid to be to forceful. When you say Wheel do you mean the bezel?
7690
OK Thanks.
