Acer Aspire AS5530-5824 Laptop Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i connect aspire 5810t vista home pre 64b laptop to samsung lcd hdtv via hdmi
Anonymous
Level 2:
  • Expert 255 Answers
  • Posted on Mar 23, 2011
Anonymous
Expert
Level 2:
Answers
255
Questions
Helped
53848
Points
934
Connect a HDMI cable to the HDMI port on your laptop and connect the other side of the cable to the HDMI input of your LCD television.This would work for you.
Anonymous
Level 2:
New Friend:
  • Expert 36 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
36
Questions
0
Helped
4960
Points
110
As long as you have an HDMI port on each hardware, just insert the HDMI cable into the ports and it should work fine.
Hope this helps
Anonymous
Level 2:
Sergeant:
  • Expert 234 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
234
Questions
0
Helped
34241
Points
752
Plug it in, select appropriate input on the tv, and plug and play in the computer will pop up dialog boxes for you to complete setup
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
1helpful
2answers
I WANT TO HOOK UP MY ACER ASPIRE 7745G LAPTOP TO MY SAMSUNG HOME THEATER SYSTEM SO THE SOUND FROM THE LAPTOP COMES OUT TRUE MY SAMSUNG HOME THEATER SPEAKERS. MY ACER HAS HDMI, VGA, MY HOME THEATER SYTEM...
HDMI should transmit both Video and Audio. It's the best quality of all of the methods. Just make sure that you have your sound set to HD sound. You can do that by right-clicking your speaker icon at the bottom (by the time), and choosing Volume Control Options and make sure that Digital Audio (HDMI) is selected.
This would work for Windows 7 or Vista Operating Systems. XP is similar, but you will have to play around with.
I have just bought a VGA canble and sound lead to use my Samsung LCD TV as the monitor for the Acer Aspire 5920. When the power lead is turned on there is a flickering constantly on the screen and an...
I hook an HP to a Samsung HDTV in much the same way. Two things, if you connect to the monitor out on the laptop after it's already started up with Windows loaded, you will need to do a restart to activate the monitor out. You can leave TV on during this process. Second, be sure you have selected the correct input source on the TV. Mine actually has a PC input and that's how it reads when I select it via the TV's remote.
Something I've done since that you may want to consider is upgrading to a graphics card (via PCMCIA card or if daring enough you could try upgrading the internal mini-PCIe graphics assuming your PC is capable of that) that support DVI or HDMI out. This method is better if you intend to connect through a home theater or surround amp.
3helpful
2answers
No image on hdtv
First off, is the tv set to use the hdmi input? if not, change tv to hdmi input and try again. If still no good, you likely need to tell the laptop to use the hdmi connector. Try this:
  1. connect hdmi from laptop to tv and select hdmi input on tv.
  1. while holding the blue fn key (bottom left side of kbd) press and release the F5 key. This will toggle the laptop between the laptop lcd display, external connectors (vga/hdmi), or both simultaneously. Let me know if this works or not.....
Connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
1helpful
Accessory for connecting Laptop and HDTV via wireless N router?
You cannot use the wireless N router for this. But you may use Warpia SWP100 Wireless PC to TV USB adapter HDMI/ VGA for the same purpose.
2answers
Cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
2answers
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
