Dell 1201MP Projector Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dell 1201 projectors displays only in yellow
Keith Brown
Level 3:
  • Master 604 Answers
  • Posted on Mar 23, 2011
Keith Brown
Master
Level 3:
Answers
604
Questions
Helped
152463
Points
1823
You have most likely lost 2 of your color guns, most projectors have RED, Green and BLUE as the projector colors (some newer projectors have added a 4th color). if one of your color guns has gone out, you may experience colors that are not correct. that is where I would start. go to the convergence routine, in your setup menu. this is where you can determine if one of your "guns" has quit working.
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
2answers
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
1helpful
It doesn't show red color. i tried to do factory reset. but still problem.
1.After turning on the projector, press "+" and "-" buttons on the control panel
3 While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Contact Dell if the colors are not displayed correctly.
1helpful
Hello, i can't connect my projector to dell n5010 laptop. no device find when connect projector to laptop. please help me.
The following is from page 69 of the 354-page Dell Technology Guide for the N5010
General Keyboard Shortcuts
<Fn><F8>
Displays icons representing all currently available display options (display only, external monitor or projector only, both display and projector, and so on). Highlight the desired icon to switch the display to that option
So the solution is just plug the VGA cable from the projector into the N5010 laptop's VGA port and then press <Fn><F8> (Function and F8 keys together).
The picture is blue and yellow only...no reds.
reset the settings to factory default. if that doesn't help, the colorwheel needs replacing.
How do i connect cable tv to my dell 2200mp projector
You can connect it directly with a composite cable. There would be a RCA(yellow) video output on the back of your cable TV. This is then connected to Video input(yellow) f you projector.
If your cable TV has Component output (threr RCA cable Green, Red, Blue), then these thre RCA could be connected to the similar one available on your Projector.
You could connect your sound als o thru the RCA out of Cable TV and input of Projector. But if you have a good AV Receiver or a sound system then it best suited for it, since the projector speaker is mono and only 2Watt output.
Let me know if there are any specific inputs required
The Dell 2200 mp projector has the following compatibility
:HDTV: 1080i, 720p
EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes
2answers
Dell 3200 Projector color green instead of yellow on VGA not on S-Video
I have found that the S-Video port has the correct colors, but the VGA port has green inplace of yellow. I believe the VGA port on the projector is the problem. I don't know how to replace the VGA port or if it can be replaced. Thanks D. James, tweezers.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
