Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Hello Lahoma, thank you for your post!
I understand that your Frigidaire washer fills with water, will not drain completely, and is flashing an "E10" error code. The error code stands for your washer fill time is too long. This could be an issue with your water valve, main control, or water pressure. You should check to make sure that your water flow is normal and that your water line is not restricted. This could cause an issue with the way water is distributed within your washer. The water pressure coming into your washer should be at 30 PSI. You can also clear out any false error codes by performing a reset on your washer. In order to reset your washer you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue I would recommend consulting with a professional technician for a proper diagnosis to be completed. I hope this information is helpful to some degree. -Matt
