Tomtom RIDER GPS Devices Logo
Posted on Mar 23, 2011
My tomtom rider 2 will not turn on - Tomtom RIDER GPS Devices
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
407
Points
I bought a tomtom rider 2 after just 3 months it stopped workink I sent it off to tom tom they sent it back new battery 3 weeks later it went again sent it back and they sent a new one to me
Anonymous
Level 1:
New Friend:
  • Posted on Apr 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
407
Points
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
1 Related Answer
Anonymous
  • Posted on Apr 15, 2009
SOURCE: Need tomtom rider 2 2nd addition docking shoe
Forget TomTom. Go buy this one
http://www.wunderlichamerica.com/mm5/merchant.mvc?Screen=PROD&Store_Code=WA&Product_Code=8600880&Category_Code=
I talked to TomTom multiple times on the phone and had same problem but finally found this. It's better quality and it's available.
Thm Tom Rider 2 can't call out while riding
The tomtom is made so you can only receave calls when you are moveing. you can't call out.
I have a TomTom Rider 2nd Edition. I need to restore the SD card how can I get this done.
You can purhcase the new TomTom Rider 2 map update for $79 from TomTom.
If you have your receipt as proof of purhcase, you maybe able to take it back to the retail store you purhcased it from and see if they can assit you with TomTom.
Contact TomTom customer support directly to see if they can assist you also.
Good luck
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Rider 2 Bike Dock no longer charges, needs repairing or replacing?
call tomtom to get the dock replace, after you insure that the dock is getting power. check with ohm meter, should have abut 13.5 volts to the base.
4helpful
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
2answers
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
3helpful
Pls describe the size and type of security screw on tomtom RIDER
I have tomtom rider 1.
There are 3 sizes of Torx screws; 3 sets of 2 screws each.
The largest is at the top back. I watched a fellow on YouTube take the back off. That was very helpful.
Someone called that T6 screw. I found a little set of security torx drivers for this.
The 2 bottom corner screws are smaller and then inside that on each side of the door are 2 more (smaller size but longer) screws.
Then carefully take the back off. There are wires connecting the back to the main board.
Take the card out before you try to take the back off.
Hope it works ok for you.
Ron
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
