When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Repair Parts for 9 1 9 10 Treadmills SPORTSMITH net
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: c956 precor treadmill
Hi
not to sound funny but are you sure that you have this tread set in the units (mpg/kph) that you require. i have worked in loads of gyms and its a common problem that people think the belt is running to fast because its set in kph and that thinks its in miles eg 9mph = 14.5kph
you can check and change the units in the club setting menu.
hope this helps :)
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
SOURCE: Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
SOURCE: The belt of my treadmill
Hi stewarvm,
you either have a loose belt or possibly a bad bearing.
grab each roller (front and back of treadmill) and try and shake it up and down and front to back to
to make sure the bearings are ok...if they move a lot, then you probably have a bad bearing...if theres no movement, or very litte, they should be ok
now make sure the belts ok by looking at it and determining if one side is looser then the other (the right side should appear or feel looser) then tighten the right adjusting bolt till the belt tracks in the center. the adjuster is at the rear, one on each side of the rear roller.
HERE is a video and instructions of how to track your belt.
its pretty easy to fix and should only take a few minutes to get it right with a little trial an error if you never did it before.
let me know if you need further help.
Bill
EX
Standing Member of G.O.T.
