Btu rating of coleman 7300 series ac - Heating & Cooling
    New Friend:
Did you ever find the answer for this? I have the same unit.
Posted on Jul 27, 2014
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: 7300 Series AC
3800 watts ran every thing just fine.
Posted on Sep 17, 2008
What refrigerant is in a Coleman 7300 Series AC Unit, on a 1995 Wilderness Camper?
This unit uses R-22. Here is a link to the service manual:
www.bryantrv.com/docs2/docs/rvp/rvp6789mech.pdf
Jul 17, 2015 | Coleman Heating & Cooling
Btu of coleman 7830-901
That should be a 30,000 Btu unit. Its been a while since I worked on them. The 78 is the series or model, the 30 is the capacity or btu's and the 901 indicates it is a Copeland compressor.
Jun 09, 2014 | Coleman Air Conditioner Shroud Rv Roof Top...
What is the btu rating for model number 7333c8664?
I believe the Coleman BTU ratings are the 3rd and 4th numbers, if so this is a 33k btu system (2.5-3 ton).
Sep 24, 2011 | Coleman Mach III Air Conditioner
We have a Coleman roof unit a/c on our RV. We are going to be replacing it and we're not sure what the btu's are. We are thinking 13,500. The model no. is 6759-707. Can anyone tell us what the btu's are...
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers
Jun 08, 2010 | Coleman Mach 15 Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
How often should i use the fan on my central ac unit?
yyoucan use it whenever you wish. The motor is rated for continuous duty so you can run it all the time if you so wish, the filer will just get dirty quicker
Jul 19, 2009 | Coleman Propane Forced Air Heater...
We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
7300 Series AC
***I guess nobody knows the answer. Ok. I'll search elsewhere.
Jun 14, 2008 | Heating & Cooling
Heating & Cooling Logo
847 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
