The air intake filter may need cleaning. Also, check the humidity
setting. You may have it set to low. In addition, it wouldn't hurt to
check the drain tube or drain hole (whichever one your unit has) that's
just above the bucket. You'll see it once you remove the bucket. It may
be clogged and is not allowing the water to drain properly. Using a 18"
long plastic Zip Tie or something similar (No wire coat hangers) that
will comfortably fit into the hole ... Carefully and gently run it as
far as you can into the drain hole or tube. The tricky part is when you
reach the bend in the tube. So, tread carefully. Once you have it
inserted as far possible, as you rotate the Zip Tie, slowly pull it out.
Rotating it, will loosen any debris. Be prepared for water to follow.
If
none of the above solves the problem, the compressor in the
dehumidifier may be low on refrigerant gas and will need to be
recharged.
Hope this helps you troubleshoot and solve the problem.
Here
is a tip that explains what can be happening to make the dehumidifier
show that the bucket is full when it is not.
Dehumidifier
Problem It shows Bucket Full
heatman101
