Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Mar 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is DU blinking on a Whirlpool Cabrio washer mean?
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Mar 22, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1025722
Points
20216
'DU' stands for Door Unlock Error. There is likely to be a problem with either the door solenoid/lock or the 'door open/closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
1helpful
Whirlpool Cabrio WTW7600XW on the display screen is says sd and all the lights are blinking
The manual that came with the machine explains that the Sd error means "suds" and that means you are putting way too much detergent in, or aren't using HE detergent. If you keep doing this you're going to damage your machine. These washers are so water efficient, you only have to use about 1/4 to 1/3 the HE detergent the bottle recommends. Suds-lock has been the culprit behind many a HE washer death since their inception. Hope this helps.
2answers
What does LD mean on the display
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1helpful
Cabrio dryer is working but there is a code "AF" blinking, What does this mean?
means air flow sounds like vent that goes outside may be plugged up with lint
DU error code
The Kenmore Oasis and Whirlpool Cabrio washers are essentially the same. Following is the Whirlpool Installation and service manual for their Cabrio washers.
The DU indicates a problem with the door Un-lock mechanism. See the section on troubleshooting2.gif and display codes.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
2helpful
Du error code on whirlpool cabrio
that code is for the door unlock error. is it possible that you may have tried really hard to open the units lid when it was locked? if so the door lock may have been broken. if not, then try to unplug the unit for a few minutes and try a new cycle.
if the code comes up again then you will have to call for free service as it has a 1 year warranty for parts and labor. yes even if you broke the lid lock!!! dont worry it happens when you get something new and are not sure how it works.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
