Philips 47PFL7403D 47 in. LCD TV Logo
Posted on Mar 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does it have an analog tuner? or do I have to buy one?
Chi Chu
Level 3:
  • Philips Master 8,457 Answers
  • Posted on Mar 21, 2011
Chi Chu
Philips Master
Level 3:
Answers
8457
Questions
0
Helped
2822811
Points
26282
LCD flat screen tv function for both.Yes,this tv can take analog tv incomming broadcating tv signal too.Tv signal are all digital now any how.
Anonymous
Level 2:
Scholar:
  • Expert 138 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
138
Questions
0
Helped
47044
Points
422
This TV is equipped with a digital TV tuner. As long as your giving it a digital signal either from a cable box or through a digital antanea, it will be able to decode the signal.
1helpful
Is the Magnavox TFT LCD 17 MF200v/17 have a digital or analog tuner?
I believe it has an analog tuner (NTSC) only. The original remote is pictured here: http://www.replacementremotes.com/philips/buy-313923807911-remote-control.html . The TV is listed as having been available in 2004 from Amazon.com. The manufacturer didn't have to include a digital tuner until 2005 for 36"+ models. For a 17" TV, they didn't have to have a tuner until 2007.
I hope this helps.
(You'll need to have a set-top box (digital-to-analog converter) to watch over-the-air signals.)
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
No problem, I just want to know if this tv has a digital tuner? It says it has a "digital comb filter". Is that the same thing?
A digital comb filter is not a tuner. It helps improve the appearance of digital content by splitting the luminance (brightness) and chrominance (color) of a digital video signal (DVD, or other set-top box). This filter is only needed when digital content is going to the TV over RF (coax) or composite (analog) inputs. http://electronics.howstuffworks.com/tv-buying-guide18.htm has some details on the filter,
Please provide the model number of the TV for additional information about the tuner. Normally the tuners will be listed as NTSC (analog), ATSC (digital), Clear QAM (unencrypted digital cable) in the US. In other countries you have PAL (analog) or DVB-T (standard definition digital terrestrial) or DVB-C (standard definition digital cable) signals.
I hope this helps.
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
2helpful
Do I need a digital converter for my Samsung LN-R268W TV?
If you are refering to signal you receceive on an antenna, then yes. It's actually called a Digital Tuner. The standard analog tuners that are in most older TV's will work for the Analog signals that you will probibally still be receiving, the Digital signals will not be available to you. This will depend on if stations in your area are at transmitting in Digital or analog or both. These boxes are the devices the government was either giving away, or making availalbe for a low cost to those whom need it via cupons. This has ended, but you can check this gov site out that talks in detail about it. You can buy the Digital Tuner boxes for pretty cheap from what I havce seen, but you will probibally need an antenna also.
1helpful
Will this tv need a digital converter box if we remove cable?
I have a clarion in dash dvd player I want to know if I can use any tv tuner for it or if I need a certain one
If you want to be able to use your remote, and touch screen functions for the tuner then you need to buy the clarion tuner to match. If you dont mind having a seperate remote tocontrol you stations, then you can use any brand. If you are buying off the web, be sure it is a Dtv converter, and not an analog tuner, or you won't get any stations.( Lots of people are trying to unload old out dated analog tuners on the web, so be careful)
1helpful
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Does this have a digital tuner?
http://www.g4tv.com/techtvvault/features/35337/Review_Samsung_CSL2097DV_DVD_Television.html
Look here, there is a phone were you can call and ask, as you can read, this article says nothing about that feature so I think is not digital ready, is a verry good combo and I never see one in my shop or other shop in my area that means is a good one, if you live in US or in a US posesion as Pueerto Rico the federal gob. will give you a $40 dollar value to buy a digital to analog converter......good luck and rate me
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
