I use this app to hide files, photos and videos on my phone. It's safe and easy to use!
LEO Privacy Applock Hide Safe Android Apps on Google Play
Hi Mykk
If you are using Microsoft windows then follow the following steps to hide any files and folder:
1. Right click the file or folder that you want to hide
2. Go to Properties
3. Now in the Attribute Section (Below the size of files or folder)
4. Now You'll be able to see two check box option i.e. "Read-only" & "Hidden".
5. Now check mark the Hidden Option in Attribute Section.
6. Click Apply Button.
7. Confirm the option to apply settings to Subfolder & files(This confirmattion is asked only if you are hiding any folder).
8. Click OK.
9Now you'll be seeing that the folder or file's color has been changed that means you have hidden file or folder Successfully.
10. Now Go to "Tools" in menu bar
11. Click "Folder options"
12. Go to "View" Tab
13. Now in Hidden files and folder optin below Select the redio box i.e. "Do not show hidden files and folders"
14. Click Apply button
15. Click Ok
To Unhide your files or folder follow the steps from 10-15, by just making changes in step 13.
You just have to select the radio box i.e. "Show hidden files and folders.
(Rate me after you have got ur solution)
-Thanx
-Romy
The easiest method is change file to a hidden file.
Right click on the file - properties - tick on hidden
There is an advanced method, change file to a hidden file
and as well as system file using MS-Dos.
I refer you to SmartUSB.net. It is a good source for flash
drive users.
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Change your flash
drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
