SOURCE: (I need a new electric motor for my air compressor. Where do I find one?
Grainger will have match motor for you. or go to baldor motors web site and ordere it.
I think I can help you guys needing a replacement CC-5440M12 120V/60Hz Ronning Motor. I have been cleaning out my shop and I have four (4) of these used electric motors. All work fine. They still have the plastic fan blade on one end and the metal gear on the other. I actually have electric cords wired up on each of them that I used to make sure they worked.
Thought I would pass this information on to you. Thanks and have a great day.
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
