My laptop slipped from my hand and fell down vertically i.e landed on the thin part of the battery. the battery had come out half way.
The problems are:
1. the screen appears stretched.
2. After i plug in the power supply the screen light goes dim instead or brighter.
Please help
bad hdd now, heads crashed,?
Laptops do that easy
but yes fan too... there are only 2 motors there, HDD and fan
one is not happy./ (use ear close)
the PC when it overheats it slows down (Intel inside magic)
or even shuts off. so most PCs do not damage actual
but is no good too use slow or dead.
sorry no fire. PCs are fire proof, smoke some sure is possible
but super super rare smoke, disktop PSU sure do make smoke some times.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
It is possible you might have picked up a virus, or a bad device driver. Try a system restore taking the computer back in time before this happened, may resolve the issue.
If the screen is not damaged it will be probably, cable between motherboard. You need to open the laptop and check if there is no loose in connection between motherboard and LCD
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :(
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
