It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
My oven light won't turn off because the door button does not always get compressed all the way. Replaced the cord around the door but I still have to slam the door a couple of times to get the light to turn off.
my oven door does not close completely either. The light rarely goes off. Is there a way to tighten the hinges?
