Question about Husqvarna Garden
I have a 16 in 235 Husqvarna chainsaw that starts find and runs for a few minute. then acts as if it is not gettting enough fuel as it starts to bog down while running and will not maintain idle.
  • Husqvarna Master
  • 2,239 Answers
It may well just need the carb adjusted, unfortunatley there is a special tool required the adjust the screws, the L screw on the carb may need richening up, so if you manage to get the tool unscrew it by 1/4 out ( anti cliock wise ) tool part no. 530035560
Posted on Mar 21, 2011
6ya staff
SOURCE:
346XP Husqvarna chainsaw acts like its seized then after a few minutes turns over fine and starts.whats wrong?
It has run too lean for a while and the piston and rings are damaged. The piston is probably picked up and grows with heat enough to partially seize when hot, frees off when it cools down. It needs a new piston and rings set. If you are lucky the bore is not too badly damaged and may go again with a new piston. When/if you get it fixed make the mixture (air:fuel) richer and check you have enough oil in the fuel.
Sep 18, 2014 | Garden
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
Chainsaw cranks and runs but after minute or two it dies. will start again but dies when trying to throttle up
Check the fuel tank vent. Does the saw leak fuel when laying on its side.? Faulty vent can cause the saw to bog down when running
Nov 20, 2012 | Husqvarna Garden
My saw runs good at idle and mid rang but when I stick it into a large limb and try to cut it bogs down and will die if I don't let go of the throttle. It acts as if it is starving for fuel. I tried to...
I have had to change a few fuel tank breathers on the 455 and 460 saws, when it starts to die try to slacken off the fuel filler cap, if it picks up again it is a brather issue, the breather is under the starter cover at the top right hand corner.
Sep 25, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
My husqvarna chain saw will start fine and run good and cut good for a few minutes then it will start running fast then slow down run fast slow down it will do that 3 or 4 times then cut off any idea...
It certainly sounds fuel related, remove the fuel hose from the fuel tank and replace the filter on the end, try the machine again, if it is no better it could well be an issue with the fuel tank breather, to test this run the saw until the problem starts to occur, slacken the fuel cap enough to allow air into the tank, if the machine picks up and runs well you will need to replace the tank breather, let us know if this works and i will will go through how to change the breather.
Feb 09, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Saw runs great then bogs down 20 sec. after i start cutting i let off it runs good then bogs again when cutting after a few sec
Check your air filter, if clean chances are your carburetor needs to be rebuilt. the carburetor has thin diapragms that get hard and won't meter the fuel in fast enough.
Jan 30, 2010 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
Runs great for 30 sec. to 1 min. then dies slowly
Is it your chain saw Husqvarna 40?
Try carb adjustments H-3/4 turn ,L-2 turns and T a little higher
I presume that compression and ignition sistem is adequate for the engine to run.Good luck
mihai
Apr 04, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvana 61 chainsaw starts but cuts out after a few seconds
Are you pumping the primer till it's full of fuel? The fuel pump diaphram is only strong enough to keep things flowing after you have pumped it up. you will need to prime it up again if you run it out of fuel or if it sits any length of time
Mar 25, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
443 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
