Normally, when a washer will spin without cloths, the washer is doing all the basics correctly. But when you add cloths, which means adding weight, the washer will not, then its a suspension rods issue. The suspension rods absorb the weight and allow the washer to spin.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
