At first you need to have the password in order to change it. If you don't have it, you can reset the router to its factory default configuration. To do that, look on the back of your router. There should be a small hole that only a sharpened pencil or pen tip will fit in. There is a button inside that hole. You want to make sure you press the reset button down for about 15 seconds and make sure the lights flash on it when you do that. Your router will reset to the factory defaults.
Access the router's default configuration address through your Web browser by entering this address: http://192.168.1.1 (see Resources). Do not enter a user name. Enter "admin" for the password. That process works for all new Linksys routers. If you have changed the user name or password in the past, use the user name and password that you created.
When the configuration screen opens, click on the "Wireless" tab and select "Wireless Security" to view the router's current security password. The "Security Mode" field will say "Disabled" if you do not have a password to secure your network.
Select the appropriate encryption type from the "Security Mode" drop-down menu. Linksys routers offer WEP and WPA encryption. WPA encryption allows you to use a single password to access the network. WEP encryption creates 10- or 26-character keys that act as your password. Some of your wireless devices may only utilize a certain type of encryption. Determine which protocol is best for your network.
Enter a password that will be required to access the network. For WPA encryption, you can write your own password. For WEP encryption, click the "Generate" button to create passwords that can be used to access the network. Write down your passwords and keep them in a secure location.
Click "Save Settings" to confirm your changes. Your network will now be secured and will require a password for access.
Click the "Administration" tab to create a password to access the router configuration page itself. Be sure to change the password from the default "admin." Reenter the password for confirmation in the next field. Click "Save Settings" to confirm your new password.
