Hi, please check the colors below for a match. If these are not your colors, please get back to me.
2006 Mitsubishi Lancer Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Red/White
Left Front Speaker Negative Wire (-): Red/Blue
Right Front Speaker Positive Wire (+): Red
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Yellow/Red
Right Rear Speaker Positive Wire (+): Light Green
Right Rear Speaker Negative Wire (-): Yellow/Green
Thanks, mate, but all the colours are different.
Here is front end of the harness (connetion to the radio) in vertical pairs
Grey/Black - Grey
White/black - White
Black - orange
Yellow
Red
- Blue
Green/Black - Green
Purple/black - Purple
The sticker says : Part No: MR935792, The radio unit is Fujitsu. If you've got an email, I can sehd a picture.
Hi, those colors are standard for aftermarket stereos. Is this what you needed?
P o w e r
Memory (+12v Constant) Yellow
Ignition (+12v Switched) Red
Ground (-) Black
Power Antenna Blue
S p e a k e r s
Right Front (+) Gray
Right Front (-) Gray/Black
Left Front (+) White
Left Front (-) White/Black
Right Rear (+) Violet
Right Rear (-) Violet/Black
Left Rear (+) Green
Left Rear (-) Green/Black
Thanks you. You actually were right the first time. I just looked at an inermediate connection harness, rather than initial wiring from the car. And the second set is what I've got with the new unit. Just one more question. Mitsubishi wiring says "Car Radio Ground Wire: Chassis".
Where should I connect my Black (Ground) wire from the new unit?
You'll have to find a bolt on the bare metal frame of the instrument panel for the ground. It should be a bolt and not just a screw. Strip your ground wire at least an inch or more, loosen the bolt, wrap the stripped wire around under the loosened bolt's head, and tighten it back real tight. OK?
can you help with same prob for 95 executive model plse i have cd player to install but no manual for the cars stereo wiring
U can consult ur mitsubishi dealer for such kind of details.
