"Too dark" or do you really mean "totally black"? I'm asking because a stuck shutter is a very common failure mode for your particular model camera.
The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Things to check first are battery contact points, and micro switches that are located on the battery and memory card doors. Details on what needs to be checked may be seen here. It won't work for every case, but it's worth a try.
Try the solution posted by frozen80 at http://www.fixya.com/support/t295396-canon_s2_black_screen. It fixed my Canon PowerShot A610 black screen (closed diaphragm) problem.
Many cameras can serve as a webcam, sure; however the A60 camera is not designed to do this. I have checked the manuals. I even have an A610 and it doesn't do it. Sorry.
In the future, here is a helpful article that describes how to accomplish this. But asking if you camera can do it, of course, is the first, and most important question. Great question.
hi maria
1:plug the USB cable in the camera body on the lefthand side, and plug outher end to USB point in computer body ,then turn the camera power on , a menu will apper on the computer screen then follow a simpel instruction .
GOOD LUCK
sam n
you will need a #0 screwdriver.
1. remove the screws on the sides
two on one side
three under the Digital/dc in / av out
2. removed the screws from inside the battery compartment
three total screws
Cheers!
PS these are small screws. Work in a well lit area!
