Features of each record mode
The details for each record mode are as follows:
RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth.
TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer.
SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored.
HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ.
3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode.
SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
