Over the past 8 years, the FS55 has had at least 5 different carburetors, and they have at least 3 different systems with different adjustments. Many of them do not have much of an adjustment and will not cure running problems. If you are experiencing poor running conditions, I would suggest some basic checks first. The spark arrestor screen is a big culprit on this model.
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at
https://www.6ya.com/expert/rolandw_c013176d62ee17ae
